Fuel pump fault
yosi
No petrol reach the engine and been told to check the petrol pump relay. Can anyone plase tell me where to find the relay?
Mine is a 1989 190e saloon (bosh fuel injection)
Cheers, Yosi
It should be behind the battery, behind a plastic cover. Remove the plastic cover and you should be able to see it under there. You can link out two pins and power the pump for testing purposes if want. I can PM you if this helps :)
Will
On a W201 I think you will find it in the box behind the fuses. IRC its a small silver box that has ribs on it. Will check the Project car to be sure.
