fuel pump
gravel
im not getting voltage to the pump when the ignition is turned on?
1998 320 ml
Your fuel pump relay is 10 in the link, fuel pump wires are blue/white , you need to measure around the relay in and out with ign on
Check the relay in the fuse box in the engine compartment.
Take it to a garage, either main dealer or an indie.
You seem to have had this problem for quite a while now, as you have started many thread on the subject and although members have tried helping you, nothing seems to have worked.
A dealer will plug it into STAR and tell you the problem.
