VitoCorleone08
Hi all,
Broke down at the weekend. Loss of power, big engine shake that went through the whole van, lots of white smoke from the tailpipe and weirdly, also the engine bay, strong raw diesel aroma. Would run at idle but not rev. Got it recovered home, and started diagnosing the problem yesterday. Now it will crank, briefly fire but won’t rev at all and dies as soon as the starter isn’t cranking it….presents like it’s out of fuel so checked injectors for leaks and all seems good….injector seals are ok, no chuffing etc from bores. Got good fuel flow at filter spigot out to high pressure pump. Pump pressure with rail feed disconnected is virtually nothing…dribbling out when cranking. Not sure how that works but I would’ve expected a strong spurt at pressure No fuel at injectors. Scanned it with a snap on diagnostic and not throwing any fuel pressure related codes. Live data (see attached pic) shows good compression and building fuel pressure, which is contrary to what I’m seeing at the injectors as there’s not a drop of fuel coming out when I crack the nut on any of them. I’m thinking it’s either the pump or a rail sensor/fuel cut off solenoid gone down. Any suggestions as to where I can look/test to pin it down to a specific part?
Massive thanks in advance…I’m in a bit of a bind as this is my work vehicle
