Disconnecting the MAF will actually trigger 2 codes (as he states above after he tried this to see if it would come out of limp mode) and force the ECU to run a default air parameter without a faulty MAF being plugged in. This in turn has worked in troubleshooting this kind of fault for me narrowing things down and most importantly enables the car to run without being in limp mode. 9/10. And if the car does not come out of limp mode things get a bit more deeper in the troubleshooting process. That is a very bold statement you made there. I can agree to dis-agree bud. Every car is diffirent but if dis-connecting the MAF does bugger all why has a load of C and E classes ive worked on the last 2 years, the majority came out of limp mode after dis-connecting the MAF's? In this case its not taken the ops car out of limp mode. So what has that achieved. It tells us that its a bit more complicated. Ide start looking at o2 sensors, exhaust back pressure, egr llines.... Ensure a legit mercedes genuine DPFE sensor, EGR is 100% ok, theres no split hoses and yes especially when there are any errors regarding cylinder error codes 1st thing to check would be injectors. Most of the time when an injector is faulty in some way the car will run really bad in limp mode or not , like it will idle erratically and judder and vibrate a lot. Ive come across instances where customers have neglected servicing their cars for years and similar symtoms caused by clogged fuel filters. I get a lot of Mercs with this stupid DPF 400% full fault carry on. Definetely a false error !
