D
Deleted member 37751
Guest
I know it's not a Mercedes but it is German and this is the only forum i'm a member of
The Mark 5 VW Golf GT TDi 140 that I bought as a stop-gap until we get our *ahem* Discovery 3 is playing up.
The problem is that it will randomly not select 1st gear . The local indy who I have taken it to has checked the selectors on the gearbox, which are fine, the clutch and dual mass fly-wheel look new and he is reluctant to start dropping the gearbox & risking spending a lot of money on a car that I will be either selling or part-exchanging very soon.
The other problem is that when the car is sat at idle it runs a bit lumpy, as though it is 'mis-firing', yet when it's put on VAG com it is coming back without ant faults I've been advised that it could be the 'tandem pump' is on it's way out which could mean that oil is getting into the diesel..
Amidst all this, the car actually drives without fault; once in motion, it travels through every gear fine and the engine has got plenty of power when needed.
The mileage is 137,000.
Any thoughts would be greatly appreciated
