- Jan 10, 2019
- Location
- Cardiff / London
- 2x E350 CDI Sport W212s, Golf Mk4 V5.
Got the dreaded coil light (during a DPF regen, probably coincidence), comes on at startup and then flickers occasionally while driving.
Yesterday I got a bit of a shaky start, too. Seems to drive fine however.
I've been doing some research and decided to change the glow plug relay first as it's so easy to change, with fewer risks. Plus it's apparently a common fault on these engines (OM642). If the coil light remains, then I'd change the actual coils. Car has done 134k miles.
Is there any downside to buying this one: Control Unit, glow plug system BERU Number of Cylinders: 6 — item: GSE116. Buy now!
It's BERU. I know there was a revision, so I assume this is the newer version.
Called MB Cardiff and they wanted £197 + vat for a new one, or £116 + vat for an 'exchange' one. The one in the link above is £74, seems too good to be true?
Cheers!
Ed
Cheers!
Ed
