I've going to go slightly mad if I don't get this issue fixed. I've tried every breaker in the N.E of England. I've tried the known good Merc breakers all over the country. I've tried ebay. I've tried the EPC parts list.
I made a mistake in swapping my 1992 w124 blue cloth interior for a dark green leather w124 from 1985.
A few of the parts were missing (fuming I was) but the main thing is the seatbelts as the MOT'r won't pass it with out them. The parts are different for sure. The entire bracket from the front and the clip at the top must be different. If I even had a picture that would be something to go by.
The rear seatbelts are way to short. This seat doesn't have groves for the belts to go in so they must be quite a bit longer. I tried fitting sprinter seatbelts but they were way to long! In addition the upper trim has a cut out for the seatbelt so they must have been fitted.
I'm hoping (and desperate now as its been weeks) that somebody with a 1985/1986 and poss later could lift the rear seat (it's just the two red clips at the bottom), compare the layout and if the same send me the seatbelt part numbers. You may be able to see instantly if you have the same rear seats from the one where it looks like its fitted.
The front bracket, which nobody seems to have seen before, requires the two screws undoing at the bottom then the trim will lift off enough to see which one is fitted.
So who can help me get my beloved Merc back on the road?
![25102011608.resized.jpg](http://www.andrewcharnley.com/misc/25102011608.resized.jpg)
![01112011614.resized.jpg](http://www.andrewcharnley.com/misc/01112011614.resized.jpg)
![10112011625.resized.jpg](http://www.andrewcharnley.com/misc/10112011625.resized.jpg)
![01112011613.resized.jpg](http://www.andrewcharnley.com/misc/01112011613.resized.jpg)
