GUTTING THE CAT...the truth ?
The honeycombe in my C-180 1997 92k cat started to break up recently, it was the original Ebberspacher one that is made for Mercedes.The internal rattling started to get worse so I bought a replacement from GSF
for £250 plus VAT after asking for a discount.First inspection looked good,all stainless steel construction made in the UK by Eurocats.It fitted straight on no problem and makes the same noise at idle and constant trottle openings,however on the gas it makes a loudish high pitch rasping noise that is annoying.If it was a low pitch rumble I could live with it but it makes the car feel somewhat un-mercedes like.Today I used a metal rod to poke out the rear wire mesh of the old cat and smashed up the honeycomb and shock the bits out and removed the glass wool that it's wrapped in.The comb was not blocked but a very clean gray colour but does have a limited life because it's quite brittle.There are no other metal parts or washers inside the cat.Any noise is chunks of comb rattling against the case,perhaps made worse by the glass wool blowing out over time. On the inlet side of the case there is a 4" long tube with holes in to I presume disperse the gas flow.My guess is the original cat has aluminium coating steel pipework and a stainless steel body which do seem to have a much longer life than the internals. My question is,
1)I have a recent MOT could I put the old gutted cat back on for a year?The back pressure of the cat cannot be that much greater than the centre and rear boxes as the cross sectional area of the cat is much larger than a straight through pipe. Blowing air through a block of honeycombe I estimate a 50% cut in flowrate.If the ECU is running a closed loop it should compensate for changes in pressure and flow rates?
2)Why is the replacement so noisy surely these things are simple to make.(I've checked that there are no leaks)I'm wondering if it's the front stainless pipe being thinner than the original and whether it has the internal perforated tube inside.
3)Mercedes want £600 for a new cat even though most cars use similar designs that sell for £250 or so.I bet Mercedes suppliers charge around £200
wholesale.
4)Has anyone fitted an aftermarket cat that matches the original in noise performance ?
thanx
adam
wholesale.
thanx
adam
