Hand/Footbrake pedal C220
HOTDOG73
c220 avangarde
My 2004 C220 CDI footbrake is not releasing properly.When you release it via the handle the alarm may sound to say it is still engaged.
I think its just a spring but not sure.
Anyone help ?
Have you checked the adjustment ?
The cable can be adjusted easily after removing a small metalplate under the back seat,also an idea to lubricate the mechanism at the sametime
Dave
Same issue with mine, thought it might be a return spring tension on the pedal or something.
I'd be interested in the fix too please!!
The compensator under the back seat partially seizes. Remove back seat base held in by x4 thirteen mil nuts. Lubricate compensator and force back all the way. Then operate back and forth while lubricating. Eventually it will return on it's own. Problem solved
There is also a black plate to remove as above
Thanks,
will give this a go at the weekend. :)
Neil
