Jan 3, 2013 #1 P Patdub New Member Joined Jan 1, 2013 Messages 5 Car mercedes 320cdi Hi all i have a 320cdi v6,year 2006 and when it hot it takes a lot more time to start and getting longer i think,any help on this thamks.
Jan 3, 2013 #2 Y8cel Active Member Joined Dec 20, 2012 Messages 257 Location Somerset Car 2008 SLK55 AMG (Sold) 2013 C63 Coupe Probably get more response posting in a different section
Jan 4, 2013 #3 A aficionado Active Member Joined Apr 25, 2012 Messages 124 Car W204 Welcome to the club As Y8cel said, you should ask in a proper section, and you'll get proper help
Jan 4, 2013 #4 steve333 MB Enthusiast Joined Oct 22, 2009 Messages 4,201 Location Dorset Car Cls350cdi in palladium,C200k in tenorite,Slk320 in red. Hi,welcome to the Forum,try posting your question in the electrical section
Jan 6, 2013 #5 OP OP P Patdub New Member Joined Jan 1, 2013 Messages 5 Car mercedes 320cdi steve333 said: Hi,welcome to the Forum,try posting your question in the electrical section Click to expand... Thanks alot lads new to all this
Jan 6, 2013 #6 Dieselman Banned Joined Jul 13, 2003 Messages 34,199 Car Peugeot 403 Convertible This sounds like either an air leak into the diesel pipes or worn injectors. Can you see bubbles in the clear plastic pipes if so it's air, alternatively, have an injector leak off test performed. Unfortunately, I suspect injectors.
Jan 7, 2013 #7 OP OP P Patdub New Member Joined Jan 1, 2013 Messages 5 Car mercedes 320cdi Dieselman said: This sounds like either an air leak into the diesel pipes or worn injectors. Can you see bubbles in the clear plastic pipes if so it's air, alternatively, have an injector leak off test performed. Unfortunately, I suspect injectors. Click to expand... Thanks alot m8,will have the test done and see wat the outcome is. have to get a new glow plug relay aswell
