Starting issues when cold om642
Thanks I found out how to test the glow plugs directly, but I'm looking for some information on how I can test them through the connector that goes to the relay module.
ie. what are the pinouts for that connector? As it's going to be a lot easier to test that way than by checking each plug directly due to access.
I didn’t know you can test through the relay , sorry buddy .
In my limited experience, if the dash glow plug light comes back on after start up then it’s a sign of a faulty glow plug and if it doesn’t it’s the relay ?? Assuming this is your starting issue
I recently changed all 6 glow plugs on my OM642 at 202,000 miles.
The glow plug light had started coming back on for about a minute after starting.
The plugs were last changed at 110,000 miles ... about 10 years ago.
The car was starting OK, but was a little bit lumpy for the first minute or two.
I was a little bit unsure how to go about it, but, with the help of past threads on the Forum, and a couple of U-Tube vids, I decided to have a go.
The first question I had was - How to get at them ?
I checked the first two with a meter - Found them to be OK - Very low resistance.
To get at the rest, I was obviously going to have to remove the batwing - A job to be undertaken with care, as it's easily damaged.
At this point I decided to change all six.
The job needs care and patience.
As said above - It's easy to snap these things if you are a bit too enthusiastic.
Use plenty of best-quality penetrating oil - At least two applications with the engine hot.
Then do the job with the engine hot.
I found one plug had gone high-resistance.
I'm glad I changed them all.
When re-fitting I coated the threads, stems and seats with Rocol "Never-Seize".
Keep the grease off the glow plug ends.
Use a torque wrench to refit the plugs.
The job was a success - No disasters.
I changed the big red seal between the batwing and the turbo intake.
The seal was in poor condition.
Again - Worth that little bit of extra expense and effort.
I must admit to being a bit wary of the job.
But - With enough care, it was less-scary than I feared.
This was part of my thread on OM642 glow plug replacement:
When fitting the new glow plugs, I torqued to 8 Newton-metres.
Do not over-tighten.
This was another related thread regarding the same job:
Just as an aside the glowplug circuit got disconnected on my tractor (3 cylinder Mitsubishi engine - half an OM642?!), and that wouldn't fire at all when cold no matter how much it was cranked :D Filled my storage shed up with what looked like steam - unburnt atomised diesel puffing out of the exhaust :oops:
The diesel engine in my Kubota mini digger will not start with faulty plugs but it does make it's presence know with the clouds of smoke 😂
My tractor is below the bhp limit where emission controls are required so without any dpf/cat/etc. everything passes straight through the exhaust :thumb: :D
Luckily it was just a multi-pin plug to the glowplug relay that had worked loose.
The mini digger is very old (I bought from a farmer for £500) as it had stopped working and he didn't want to spend any more money on it.
It took me half an hour to find a problem with low fuel pressure and one rebuilt pump later it was working 👍
Blimey - my car is on 205k with original glow plugs and starts up fine - I think I'll give this a swerve until needed!
