jupiter2step
I'm no petrol head, but as I understand it, a head gasket is essentially a strip of rubber. So why on earth are they so costly to replace? I assume it's the labour cost?
Long ago when I were a lad, your average 16yr old could change a head gasket on a mini or an escort in inder 2 hours (the good old pushrod engines), with a handful of spanners and a new gasket. Other gaskets couild be made from gasket paper or in extremis cereal packets. No other parts required.
Unfortunately, modern cars being more complex require more dismantling, and numerous new gaskets/seals/head bolts etc and some people renew cam belts water pumps tensioners etc at the same time as an insurance to avoid replacement in their own right.
It is called progress
But then I turned the crank to see the pistons go up and down...and disturbed the dry liners (how could I know about those). Took a lottttt longer to put back together again.
They would be wet liners due to being in contact with the coolant. Dry liners are pressed into the cast block so are in contact with metal.
Mercedes gaskets are complex bits of engineering usually made by Victor Reinz. Some background reading to help you change your mind.I'm no petrol head, but as I understand it, a head gasket is essentially a strip of rubber. So why on earth are they so costly to replace? I assume it's the labour cost?
I thought you might know.
I seem to have a problem with new posts and threads now.
I've posted this post http://www.mbclub.co.uk/forums/1205226-post92.html into this thread http://www.mbclub.co.uk/forums/wheels-tyres/109137-me-mechanic-7.html#post1205226 and it neither shows in the new posts or main menu screens for me.
Can anyone see the post, if not there is a problem.
I've tried to create a thread in feedback and in general about this but can't do it there, as when submitting the thread the submission just hangs, but all other forum functions are working.
