Head unit stolen w213
kaermaa
london
E220D W213 2018
Hello everyone, I have a 2018 W213 E220D been stolen recovered the thieves have stolen the head unit. I am trying to buy a used one on ebay but there are so many different ones with different amount of ports and part number, can someone help me find the right part number. I have the full digital display and my vin is
WDD2130052A465226.
I've attached the link to two different ones I've found would either of them work after I have it coded in ?
would appreciate any help thanks
MERCEDES E CLASS W213 HEAD UNIT DAB GPS CONTROL UNIT A2139003026 | eBay
https://www.ebay.co.uk/itm/256142308299?epid=21030749994&hash=item3ba34573cb:g:2bMAAOSwNQJksmy5&amScreenshot 2023-10-23 135217.pngdata=enc%3AAQAIAAAAwM99UCB6QhfnfMKXgMoQnFOFNcQQmnoutSLxBe3r%2Ft05depsjfLi5KtdkqR%2BAQzQVpSs5exQqjjIQC8nGCmk1%2F%2BhD805m9bBpYaa9sRFDhHquyMsaWYDsrCeLGEB6Owhb1Y%2FV1i44R%2FRn69fWpSx1L0YAnyfNvYBrAj2IftITmcaQK0k%2FjqREtPF6FWvG3JCAip1gfHdPDy84Fo5dvSdhZStt6RtdwWOiI4YxZ8c4S9hCgCnq%2Fv5TFHSbF5EtH%2BSrw%3D%3D%7Ctkp%3ABk9SR6TAq8frYgive
They will need the anti-theft sorting out. It can be a pain. Contact the guys at comand.co.uk and they can help.
I called command last week they told me they will get back to still yet to hear from them will try call them again tommorow. Do you have any idea if either of them will fit ?
Hi
That car needs COMAND NTG5.5. - none of the units in any of the links by the OP or those above are correct - they are all Audio-20 NTG5.2 or NTG5.5
You won't be able to use a used one. (a) you need the anti-theft PIN, and (b) you won't be able to install the map - it will install and then not activate/
You've also got a load of damaged wiring there (I can see a loose ground wire and a damaged HSD cable at least)
Go see www.comand.co.uk
