Hi all fountains of knowledge.......... I'm fitting C250 AMG W204 (2012) Coupe Diesel FACELIFT headlights to a PRE-FACELIFT C63 W204 (2008) 4 Door, and I've got everything working APART from the dipped beam...... PLEASE HELP..........
Both cars have the same 14 pin connector, however, there are 10 pins used on the C63 (Pin 1,2,3,4,5,6,7,8,9 and 10), and only 9 pins used one the C250 (Pin 1,2,3,5,6,8,9,10 and 11).
I have connected 7 wires (highlighted in red below), and got it mostly working APART from the dipped beam.
(C63 W204 Chassis 4 Door 2008 Pre-Facelift WIRING) (C250 W204 Chassis Coupe 2012 Facelift HEADLIGHT)
Pin 1 - CAN Low NOT CONNECTED (Don't know ?) Pin ??????
Pin 2 - CAN High NOT CONNECTED (Don't know ?) Pin ??????
Pin 3 - Side Light Pin 3 - Side Light (C-Light) - WORKING
Pin 4 - Side Light 2 N/C
Pin 5 - Ground 1 Pin 5 - Ground 1
Pin 6 - Xenon Headlamp Pin 6 - Xenon Headlamp - WORKING
Pin 7 - High Beam Pin 8 - Corner Illumination (Comes on when High Beam is On) - WORKING
Pin 8 - Indicator Pin 1 - Indicator - WORKING
Pin 9 - 12V Supply to Headlight Unit Electronics Pin 9 - 12V Supply to Headlight Unit Electronics
Pin 10 - Ground 2 Pin 10 - Ground 2
Pins occupied on C63 Headlight 1,2,3,4,5,6,7,8,9,10 and 11,12,13,14 not used (TOTAL in use, 10 PINS) - Pins occupied on C250 Headlight 2,11,3,5,6,8,1,9,10 and 4,7,12,13,14 not used (TOTAL in use, 9 PINS)
I am left with 2 remaining connections on the headlight (namely pins 2 and 11), but I cannot get the dipped beam to work?????????? (when I put headlights on it goes straight to high beam???????).
As far as I am aware, there is a shutter motor that is controlled (somehow????) to shield the xenon headlamp bulb for dipped beam, but the shutter is supposed to ONLY open up for high beam.
Why is the shutter open all the time? How can I control it????????
