NikolayV
Hello Guys, awesome MB club. Right so i have plans on buying a Clk 200 w209 that is driven 180... what are usually the problems that people have had? i have done my research about the model and its engine.
Thank you for your fast response! Should also have promised a little bit more information It is a Clk 200 w209 with the engine. It's a cabriolet. I did the research about whether you should check the hydraulic fluid before you start using it or just clean it before you start using it. I am from Norway but i live in France so i am buying the car there and i will be driving it back to france. Its been staying a bit without anyone driving it or starting it. So i imagine the first thing needed will be an oil change, brakes and pads bc there rusty and then do a diagnostic on the car see if anything is hiding.I had a CLK220CDi for 13 years and 150,000 miles. After 10 years the exhaust needed replaced and the brake pipes. Other than that, mostly tyres, brakes and ball joints.
Should have added, started to rust very early, MB had it fixed under warranty but it kept coming back anyway. Check the paintwork, some rusted, some did not.
Thank you. will doCheck inside the front wings leading edges (you may have to remove the liner) Dirt builds up there and can cause rust inside out
thank youMine was a W209 coupe, check the auto box has had oil changes, should be done every 60,000km.
Thank you manCheck the engine doesn't rattle on a cold start. The M271 engine is notorious for stretched timing chain and worn sprocket problems.
Also check the plugs on the cam magnets on the front of the engine for oil wicking. If there is oil in there, it may reach the ECU and cause more expensive problems.
As you can tell, the M271 wasn't one of Mercedes finest engines. And I have one.
