rossy
- Feb 19, 2006
- Location
- Bolton, Greater Manchester
- Me:-CLS55 AMG & ML280 Edition Wife:-Pug 3008 GT Line Premium
Talk about me and bad luck!! (health issues too...)
History...
Fitted BOTH new batteries about 3 months ago now as car gets little use and if it was left more than a week gave the "low battery multimedia functions disabled" warning...but always started no problem even then and then everything would spring to life after a few mins driving.
Fitted the New batteries (following the recommend way) and its same but now only after two weeks stood which I believe can be normal....?
Anyway, some may know I had the idler pulley disintegrate on me which destroyed the 6 rib belt....it now has new billet pulley from USA and new belts...fitted this Tuesday (3 days ago).
It would not start after as I had to drive it home without the belt few days before...followed charge instructions which stated to connect a battery charger to the Front Aux Bat positive and chassis earth for negative...this did not seem to charge the car up at all tho???
So popped and stripped the boot out and using JUMP Leads jump started from my other car via the main battery in the boot with no problems. Left it running 15 Mins...checked electrical all fine..i.e. window auto up and down etc so had not lost setting so no reprogram needed. After the 15 Mins I turned off and it started again fine on its own....
Come to pull it out this Morn and its completely dead!!!!
Now this is were it gets interesting!!!
I've only had the car 6 months and It only came with one key! I have always had the plan to get another...but winter and lack of using it mean its not yet happened! (which is a real shame now)
Come to use the BLADE to open the car and it only has a god dam blank in it!!!!
Who in their right mind would get a new key and not have the blade cut?
Anyway I am where I am...(which is slightly stressed to say the least)
Local trusted car Locksmiths on route as I type....but...
While waiting I replaced the already new-ish key fob battery as bought a few Duracell ones...but no joy car still dead. Go back to the garage to make more room for the Locksmith to work and the car is open??????? What the?? It did this itself?
Pop the bonnet and stick the charger on the aux bat same as above but the car is still completely dead...like nadda with the charger on????
Charger now says fully charged but car still dead and can not get into the boot via key button, door switch dead and obviously the blade key until I HOPE the locksmith can cut my blank.....
So once I can get in the boot (trying to stay possessive)....whats this SAM thing I've read about and could it be the cause of all this? I've check every FUSE I can get too (so not boot ones yet) all ok
It almost seems the Aux battery at front and the one in the boot are not connected....I though they would be?
What do you guys/girls think is going on???
please help before I loose what little hear I have left!!!!
History...
