Wondering if someone can help - I have spent the weekend cleaning the inlet . throttle actuator on my GLA 220d, 2016 with an OM651 engine. However after re-assembly I cant get it to start. The engine cranks but does not fire.
I only took off the inlet pipe and not the whole manifold, so didn't touch the fuel system.
I have Star, and no faults are showing. Tests on the throttle actuator seem fine - moves to the angle commanded to. On the startup test though I am seeing "Ignition OFF / The combustion engine was not started":
Note that the battery was flat after trying to start a few times, and having the ignition on when using Star - so that is I believe why the battery voltage is so low. However sensors seem synced, fuel pressure OK as far as I can tell. I am going to try again after charging the battery as maybe the battery has been too flat since the start of trying, however was OK before starting the work, and I think would have been OK on the first start after reassembling.
Anyone any ideas - especially with the "Ignition OFF/ The combustion engine was not started" message?
Thanks in advance!
Thanks in advance!
