evan86clc200
Hi all.
Having just driven all the way from London to Norway I have a car issue.
Its a CLC200k. I put a new engine in it as the timing chain snapped previously. The car sat not moving for 7 months. When the new lump went in a light came on (ECU) I had it checked, they said it was the MAF, and probably as it had been sat for so long, so could be dusty etc. They cleared the code and all was fine.
Last week it started running rough when Idling. When I put it from Neutral to Drive it jolts forward a little, and when I drive its in some sort pf emergency mode and doesnt change from the gear it goes off in. No light is on the dashboard. I thought it could be related to the MAF?
Everything is super expensive here so I ordered an OBD2 Scanner and plugged it in today.
The 3 codes were
P201C - Powertrain
P201D - Powertrain
P205A - Powertrain.
Can anyone help? What does this sound like it could be, and ay help on how to fix it.
Thanks so much in advance!
The 3 codes were
P201C - Powertrain
P201D - Powertrain
P205A - Powertrain.
