HELP please with these flashing green and red lights
GILES
Burton on Trent, Staffs
1997 C180 Classic Auto
Hi guys, am a newbie on here, so apologies if this might be a moot subject, but I am well and trully stuck nonetheless.
I have a '97 C180 Classic, Auto and up till now not a single problem. Recently I lost my last set of keys and had new set made via the main dealers..in the meantime, I had the car towed back home. I had to be rear-lifted as it is auto and was in Park.
Keys arrived, but have the dreaded red/green light scenario on the mirror. Starter turns but engine wont kick in. Fobs are working no probs to unlock,lock, alarm etc....have tried new batteries in fob, charging car battery, synchronising the key, and still nothing. Would love to disable/bypass the immob as the car is old anyhow....is there a way I can do this, or do I have to fork out once again to the dreaded Dealers??
Thanks in advance and sorry for the narrative...just trying to fit in as much info as poss
Immobiliser PS Welcome to the forum
thanks mate...any ideas what i can do to make it start, or is this a dealer-only remedy??
I`M NOT SURE MATE BUT SOMEONE WILL COME ALONG :thumb:
hi some one i know had same problem i think he had to go to the stealer,not 100% sure though
Thanks guys...am trying to avoid giving them any more of my hard earned...already donated £168 for a new key!!....not a speck of gold on the thing either!!
You did have the ignition ON when you were synchronising the key ?
is this not the diode in the mirror issue?
replacement mirror is the easiest option, plenty cheap on fleabay!
Very Very cheap ;)
Nice one, thanks.....will try that and keep you updated. Might be a bit of a daft question but would both lights work with a duff diode??
thanks for the advice guys...quick update. I've replaced the internal mirror, and with all indexes crossed cranked the engine...alas, the same two lights are flashing and car wont start!!
Hey all, update!!
Having spent several days on different forums, harassing Google etc, have been to the Stealers..nice bloke called Pete told me my immobiliser is not disengaging for whatever reason. The car is 13 years old now and am not bothered about having the immobiliser, so been looking at ways to bypass or disconnect the system. so far to no avail, but am calling an auto-electrician over to have a look. Fingers crossed, this wont be silly money. I will share the procedure if this does not break any forum rules as it seems a common problem with our aging beauties.....thanks all.
I'll be interested to hear the outcome, cant see how that would break any rules,carry on !
Hi Giles - I've got same problem engine cranks but will not fire and red/green flashing lights on mirror. I suspect either CPS or Immobiliser. Did you get yours disabled? If so how?
Done plenty of work on this myself have a look HERE
Other threads of mine cover it also if you search.
Hi same problem I would like to bypass the immobiliser.
can you let me know please....car would start because that also it would lock,unlock
