Help required
merc man
London
Mercedes C180 kompressor,CLK V6,Fiesta ST,Rs Escort,IS200 Sport,Renault Clio V5
Hi there all
I went out this morning and parked my car in my universities car park, on my return i tried to start the car and sevral times it hessitated and failed, i then waited a few minutes and tried it again and it hessitanly started up and stayed on and was running rough for a few minutes and then i took it for a slow spin and turned it off and it restarted fine, i noticed the engine check light come on and i had the scanner in my boot so decided to scan the car and the scanner came back with this list of faults.
PO336 - crankshaft position
sensor A CKT
RANGE/PERF
PO335 - crankshaft position
sensor A circuit
malfunction
I cleared the faults and the car ran normally on the 15 mile journey home, im jus concered what these codes mean and where these parts are located and what i can do to correct this problem/malfuction
ANY HELP WOULD BE APPRECIATED AS TO THE LOCATION/CAUSE OR ANY INFO. THANKS IN ADVANCE.
part number
hi any ideas where the part is located in the engine and the possible part number or prices. Thanks
