Help! W211 Xenon Ballast replacement
Indie Chana
CLK
Hi all.
I'm having trouble trying to get my passenger side xenon to work. A garage told me its most likely the ballast/control unit that needs changing.
I really need some advice. I managed to locate the ballast under the bumper(1st Picture attached). Is this just the ballast or the control unit as I don't know if they are different things or is this both as one unit?
I have found a after market one online (2nd picture attached) and I want to know if they are the same and it will be compatible.
Any advice and help would be highly appreciated.
D1S ingintion is fixed on bulb. Then it must be a ballast unit, if bulb and wires are ruled out.
Hi all.
Thanks in advance.View attachment 137066View attachment 137067
A year and a half ago - wondering how you got on with this?
Did you go with the aftermarket ballast unit?
- Believe it would need to be SCN coded.
