The problem starts when you turn on the ignition and the lights are in auto mode (this is in an ML350 03 by the way) If it is dark and the sensors put the lights on they come on in high beam. You need to go to main beam to turn this problem off but then the high beam or the flashers don,t work you need to be in auto again. Then the problem just stops
Anyone out there had this or heard of it before?
