How can i put out my cooling command
basamir
DONE: How can i put out my cooling command
Hi all,I have a W202 with manual cooling system and i want to know how can i do to put out my cooling command up off my radio.Thinks a lot.
ok i'm talking about the mechanism with rollers and buttoms to command cooling system above the radio inside the car plz
Do you want to remove the controls for the heating A/C system ?
Are you asking how to take off the dashboard fascia to get access to the fan controls?
i think what he wants to do is re position the cooling controls above his stereo system.
nope just re read it and he's asking how to take apart the dash and get to the cooling controls.
i have some problems with cooling controls and i want to put it down to do some welding. But i dont know how can i put it down.
I think he means that it's not working right and needs repairing!
Must be a W202 owner on here who has taken the dash apart?
ok i know that my english is very bad, that's what i m looking for plz:
I want to know how to disconnect the ordering of the manual air-conditioner located in top of the radio. is what I must transfer the radio, to open something to be able to transfer the plate of wood placing the radio and the ordering of air-conditioner.
Shude's how to on fitting command shows how to do this - actually this involves stripping far more than you need to - don't remove the armrest -just start with the two screws just underneath the radio.
u are better than me:D
OK. I must draw to the top or towards bottom the block out of wooden lodging the radio and the order of air-conditioning.
you have to pull out the radio if you can.
There are 2 screws in the unit space under the radio at each side, above the ashtray. That would get your facia out. Then on the sides of the cooling unit, there are two screws as well to take that out.
Ok thinks i found it, there are exactly above the radio.
