- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
Used the A-Class over the weekend to visit friends in Yorkshire, a 158-mile journey each way. I'd done around 90 miles of local running around between filling the tank and setting off, and the range indicator said 280 miles when we set off from home, but I knew from experience that number would climb as the economy improved once cruising at constant speed up the M1. Sure enough, when we arrived (158 miles later!) the range indicator said 230 miles were left. Excellent!
But then we did (quite) a bit of local running around while there, and on setting off for home yesterday the range remaining had dropped to 148 miles, with a 158-mile journey ahead. I wasn't particularly concerned as I knew there were several filling stations in the last 30 miles of the journey meaning that I wouldn't get my trousers pulled down by having to top up on the motorway, and sure enough as the journey progressed the 10-mile indicated range shortfall turned into a 25-mile indicated range surplus. I was keeping a good eye on the remaining range as we closed in on our destination and it was consistently 20-25 miles greater than we needed until it went below 30 miles remaining at which point the display extinguished. Undeterred, I continued the remaining 8 miles and we pulled onto the drive at home with the fuel gauge reading completely empty.
This morning I toddled off to the local supermarket filling station where I pumped in 50.21 litres. The tank capacity of my A220 is 51 litres, meaning there was less than 1 litre of fuel remaining
So has anyone else run it closer to the edge?
