JcMercZ
- Oct 31, 2011
- C230 Coupe (with AMG styling pack), W114 280e, W123 230e, W124 220 estate
Has anyone got any ideas as all we have tried has so far failed.
Engine is old m110 280.
Basically just under the inlet manifold there is a bronze Plug i need removed as the head i had previously has a water return spout, this one is blanked.
We have tried the usual soak it with wd40 used a long bar, tried freeze spray, and a little heat (only on the bronze blank/plug). It has not budged!
Now im stuck!
Engine is in car, manifold is off. Plug is a flush fit in block, something like a core plug. It has a large hex/allen key fitting.
Now im stuck!
