Oct 21, 2019 #1 johnlewis1964 Active Member Joined Aug 17, 2017 Messages 267 Car 2008 C180 Kompressor. Hi folks need a bit of help on tick over when car is warm it seems to be hunting idle from about 600rpm to 900 rpm any ideas thanks.
Oct 21, 2019 #2 DSM10000 MB Club Veteran SUPPORTER Joined Jul 12, 2011 Messages 15,758 Location Near Salisbury Car MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1 johnlewis1964 said: Hi folks need a bit of help on tick over when car is warm it seems to be hunting idle from about 600rpm to 900 rpm any ideas thanks. Click to expand... Check all intake hoses for air leaks, there are a number of hoses including one or two under the air box which are difficult to see and to access but often split.
Oct 24, 2019 #3 RichardF Active Member Joined Aug 24, 2013 Messages 686 Car Sl 320 I had a sticking purge valve that caused this, it also flagged a lambda fault. Any codes? Agreed it sounds like a vac leak on the intake.
Jul 23, 2020 #4 OP OP johnlewis1964 Active Member Joined Aug 17, 2017 Messages 267 Car 2008 C180 Kompressor. RichardF said: I had a sticking purge valve that caused this, it also flagged a lambda fault. Any codes? Agreed it sounds like a vac leak on the intake. Click to expand... No codes
Jul 24, 2020 #5 optimusprime MB Enthusiast SUPPORTER Joined Dec 29, 2013 Messages 6,225 Location Kidderminster Worcestershire UK Car Mercedes W124 260E M103 Check to see if the oil filler cap is on secure . And that your fuel filler cap is secure .
