Tomhengler
I'm getting the 3 flashes on A/C, I've had the A/C regassed but A/C still not working.
Any ideas Guys
Any ideas Guys
Yep, that's always been my experience.I rather think you have to run the compressor, and therefore the engine, to recharge the system.
That's not my experience whatsoever.Ac must get the go ahead after a regas, either with an icarsoft scanner or star.
Used to be , maybe its changed , for the better.Yep, that's always been my experience.
Car running, air con on and temperature set to the lowest setting.
Isnt if obvious what the issue is then? You need a new condenser! Have I missed something?I got the regas done at ATS
He told me I had holes in the condenser before he regassed it.
After regassed the light was still flashing so he took the gas back out and didn't charge me anything.
Hi, would i have to get the car on star, to complete the process, if I used them.Isnt if obvious what the issue is then? You need a new condenser! Have I missed something?
I use www.wechillanycar.com for a home service. They will tell you what the issue is and can replace parts if required.
They have done my SL twice now and were able to reset the codes both times.Hi, would i have to get the car on star, to complete the process, if I used them.
Thanks will bear them in mind, how often should the a/c need re gassing, as I feel that my car is adequate, but would prefer it a touch colder.They have done my SL twice now and were able to reset the codes both times.
You have my sympathy & empathy. Have owned an SLK & SLC both purchased used with very low miles & BOTH had a/c issues sorted at moderate & excessive cost by a local independent Mercedes specialist. Both issues were down to poor quality components. Compare that experience with 4 company Fords/Toyota's & Vauxhalls that did 150k miles each & a private Honda & Audi- NONE had an a/c failure - or alloy wheels that were infected by the dreaded white-worm (delamination).I'm getting the 3 flashes on A/C, I've had the A/C regassed but A/C still not working.
Any ideas Guys
How long is a piece of string? If a car is used regularly and the aircon is left switched to automatic, the seals won't dry out and allow leakage nearly as soon as if the car is little used and the aircon is switched off.Thanks will bear them in mind, how often should the a/c need re gassing, as I feel that my car is adequate, but would prefer it a touch colder.
