IFFY100
Looking for auto ramps and have pretty much narrowed it down to quickjacks with extensions. However came across this Eureka Fabrications any ideas?
So I did a lot of research on this subject (not sure if I've covered everything) and had narrowed it down to three lifts. QJ, full height scissor lift and midrise scissor lift. I had to pretty much rule the scissor lift out (although the best option) because it is apparently very heavy to move, needs to be fixed to the floor and may need tinkering with the electronics. The mobile midrise then seemed a good idea but there are bars that run down the middle of the frame which probably would make dropping a gearbox or engine a bit more challenging. I'm also unsure how I would transport to a new premises in the future,which is something that might be on the cards soon. QJ is easy to move around and seems to be an easier system to implement, but will a gearbox drop be possible or fun?Costco do the Quickjack slx for around £1300.
About as good a you can get if you don't have room for a proper 2 post ramp.
I'm about to bite the bullet I think.
I lost my garage with 4 post a few months back and realised I can't be ****d to jack cars up and use jack stands etc.
I don't have room for a proper 2 post, so the Quickjack looks my best bet.
Please buy it (pretty Please) . I have been looking at these for a while , I have checked measurements online etc as I am extremely pushed for space where I plan to work on cars.Costco do the Quickjack slx for around £1300.
Same with my car.....cured by cutting two 3 feet lengths of scaffold plank and using them as ramps to get on the ramps!.....even my old slammed Mitsi GTO could get up on the ramps using this method.I bought some wheel ramps, however, the Porsche is too low to 'drive up them' although I did jack the front up and put the ramps under the front wheels.
