You will only do 2 things, make your car sound like a tractor and wear out the engine twice as quickly induction kits really should be left on the track where longevity is not an issue, Diesels have a quite unpleasant induction roar that doesnt change note much as there is no vacuum, no doubt you could rig something up to the 2 inlet horns but it would be a custom fit jobbie and god only knows where your going to fit the actual filter body, if you look you will see each air filter is fed direct fresh air from the front of the bonnet anyway, get a remap much better
