All UK automotive fuels have some detergency included in their additive package that provi
All UK automotive fuels have some detergency included in their additive package that provides some degree of 'keep-clean' functionality, and in general most are OK. All must at least meet the specifications in EN228 (petrol) or EN590 (diesel).
Premium brands such as Shell, BP, Esso and so on, use more advanced additive chemistries that they have often developed in conjunction with major chemical companies. These are not typically included with fuel products destined for retail outlets of other companies. Having unique additive technology is one of the main differentiators for the major oil companies.
Shell Fuelsave diesel and petrol for example have very good keep-clean performance. So used from new the relevant parts of the engine will stay quite clean.
Shell V-Power and similar fuels have either different additive technologies or more additive(s) than the main-grade offering so to provide enhanced keep-clean and indeed clean-up properties. In other words, existing deposits will be removed over time/distance by using these fuels.
V-Power petrol is also higher octane than regular main-grade petrol. Premium higher octane fuels from other manufacturers are available of course...
So to answer your question, running 1000-2000 miles on a premium fuel like Shell V-Power will pretty much remove deposits from the injectors. With port-injected petrol engines, the intake valves will also be cleaned up. Thereafter running on a decent main grade fuel will keep things clean.
thanks very much, so much
