Instrument Cluster Gears?
Murphyslaw
2002 Mercedes E270 CDI, 2010 Toyota RAV4 XTR
I have a broken instrument cluster - speed needle sits between 20-25mph. I understand the majority of cases have seen this issue fixed by either gluing the big gear (the 8cm gear on the back of the cluster itself) back together or by acquiring a working cluster and swapping either the gear over or replacing the circuit board off the back with the other to avoid any complex remove/repair/recoding process.
Has anyone been able to get hold of aftermarket gears before? I hear you cannot get them from a dealer - its a new cluster that is required (found some on eBay).
Anyone with some cheap fixes?
Just found this and thought I would share:
BENZ Speedometer Gear-Speedometer Repair-Online Shopping
No idea if they're any good, but if mine is bust (hope to find time to check tomorrow), one of these will be on order!
This should not have posted twice - moderators, please delete this post as I appear unable to do so.
Thanks and apologies for the inconvenience.
