mercboiuk
.....a rather loud noise is coming from the rear, o/s.
I pick up the car on Wednesday night after the major service and rust repair, used it on Thursday, then Friday evening (this evening) the noise begins.
I exit a junction on a main road, and crest the camber. In the slippy conditions, my o/s rear spins a little. This often happens on the unloaded rear in wet/greasy conditions, unless I go out VERY slowly - I'm sure fellow E320 drivers find the same thing!
Anyway, as the wheel spins, I notice an irregular vibration through the car, and the noise begins. Sounds metallic-like and occurs under load (ie. acceleration).
So at half 5, I call up my Merc Specialist. I ask him if he can check it out, so he said "bring it over, and I'll stay here". He didn't mind that I couldn't make it over until half 6, even though they close just after half 5!
I get to the garage after a VERY nervous 10 mile drive, listening to the noise getting louder. The mechanic test drives it, hears the noise and we both inspect the car while it's on the ramp. My o/s drive shaft has too much play in it
So it could be a drive shaft or, worse case scenario, even the diff!
But here's the annoying part. Assuming this worst scenario, the diff is only 3 years - and 25,000 miles, old! I'm not the slowest of drivers, but I'm certainly not a hooligan behind the wheel.
He'll investigate it further on Monday, to find out exactly what is wrong. Depending on parts availability, it could be away another couple of weeks
Whatever needs fixing will be fixed, but I'm rather disappointed the diff could be knackered after such a short time - the original diff was replaced with this new item supplied by Mercedes!
Now I'm sure a fair few of you will know, Mercedes have a 2 year warranty on parts supplied by them. If it is the diff, my mechanic has already said he'll try to fight to get some form of grace payment. What do you guys think to my chances of that one?
Still, after 3 initial weeks, I got one day of driving pleasure!
Darren
Darren
