Kombalar
First: English is not my first language so sorry about possible spelling errors (or wrong words used).
I just purchased my car: MB 2014 200 CDI OM651 with 7-speed automatic transmission
As the topic title says: All shifts go up and down perfectly and this jerkiness happens on the 3rd gear mostly. Also when I put the car in the manual mode. I drove uphill from different gears and no jerkiness with gear 2 (1000-2000 rpm) but in the middle of hill it switched to 3rd and I let the rpm go down and then suddenly accelerate, it becomes extremely jerky and bumpy between 1400-1900 rpm..
When I performed the same test with 2nd gear (same rpm) no jerkiness at all.
Maybe with 4th gear same thing, but not as much. It's harder to test. But on the road with 5th and 6th gear (higher speeds) I have no problem.
What is your prediction? Is the gearbox broken for good? According to service history the trans oils have been changed about 60.000 miles ago.
All gear changes are okay and all problems occur between 1400-1900 rpm. When there's more RPM, I have no issues at all. The problem is not jerky switching at all but when the _gear is on_ and I "stress" the car in this certain RMP range it starts.
I'll take the car to repair shop asap and they'll take the codes but couldn't arrange it before next Friday. So it feels quite bad with new car right now.
I'd be EXTREMELY grateful if you could answer. What does this sound to you? A gearbox failure?
Timo from Finland
Timo from Finland
