key fob
mitch1981
c class cdi 220
hi, car is c class cdi 220 2003,with only 1 key, thought batt were going flat on fob as sometimes took a while to open car, cleaned batts and fob worked ok then 10 mins later it stopped and would'nt unlock car used blade key to unlock setting alarm off put fob in ignition but noting happened didn't click in, no ignition lights,dissconected batt on car to stop alarm. is my only option paying 150 for new fob, can anyone help
If your key fob is broken, the correct option is not buying a new one, but two. One should never accept a single key only.
If it starts your car OK when the alarm has been disarmed, then it could also be the remote key receiver at the car. Even that would be unlikely if it does not work via the RF port nor via the IR port (did you aim at the IR receiver at the door?).
Television would give good advice on fixing the key if it turns out to the issue (you can search for his previous posts on keys).
if battery is low, hold the key to your head and press button... it works... im not crazy!
thanks for the replies, no it doesn't start the car when battery is disarmed and no the IR doesn't show when looking through a digi camara
Im going to ring MB at milton keynes on tuesday would that be the cheapest place, i dont doubt your abilities have you fixed a few before
Thanks for your help I'll ring MB and sort a new one and get back in touch about sending my old one to see if you can fix it if thats ok with you
is there a common fault on the circuit board, a bit of carbon was loose that was covering a component rectangle shape, could this mean any thing
the coil is still on, its from the bit near the white plastic fastner and the top button if looking at your pic
it doesnt start the car or open/lock it, i'll just have to get a new one is 150 a fair price
it just looks like a cover for the component, ive held it on with the batteries connected too
