dogday
Thanks. And is it correct that the rear wheels don't have a magnetic ring built into the bearing?Sorry, yes it was.
Rear wheel on my 2010 E350 has a pushed on ring with a magnetic strip around the outside, it had separated from the metal inner.Thanks. And is it correct that the rear wheels don't have a magnetic ring built into the bearing?
Nice one Popell. It must have been a great relief when all those yellow lights didn't reappear ! Had another go at mine. Jumped up and down on the wrecking bar and 14 stone still wouldn't budge the axle nutRear wheel on my 2010 E350 has a pushed on ring with a magnetic strip around the outside, it had separated from the metal inner.
I finally got round to fitting the Mercedes’ purchased sensor this evening and lo and behold, it berluddy works!,
Abs esp all working as is cruise, attention assist, hill hold etc.
Just in time as I’ve got to nip back down to London tomorrow evening, and the gritters are out.
Also, if the nut is that stuck then I dread to think how easily axle will come out of the hub !! I did a lot of work on my cars in the 80's but the prospect now of sitting out in near zero temperatures is making the £150 seem a better option. As you say, the other side could last for many more years and I would not change a working side for the sake of it.It must be exasperating to have a nut that won’t budge!
It’s also a bit of a niggle that I had to buy genuine to get it working, unlucky with the claimed compatible eBay one I guess and the GSF appears not to be for 2010-13 regardless what they say(info from another site)
There is a logic on doing both sides but rather than make work and the fact it could be fine for years, if the lights come on, I’ll know where to start.
What I would say is that I think the reluctor ring is likely to be the culprit in the first place. I’ll probably get one and keep it in the garage for the fateful day.
As it gets colder and darker on an evening, that £150 sounds more and more reasonable!
I think I would have put a little heat into the nut(think Brûlée torch rather than blowtorch) and if that failed, try some pipe freeze, just to try to shock the nut apart from the stub but I really didn’t have a problem, have to got the hammered ‘tangs’ fully clear?
My car does stop start unfortunately…
Just food for thought - I may have been unlucky, but both front sensors on my S204 failed at about 50,000 miles pretty much within 500 miles of each other. NS first, then OS.Also, if the nut is that stuck then I dread to think how easily axle will come out of the hub !! I did a lot of work on my cars in the 80's but the prospect now of sitting out in near zero temperatures is making the £150 seem a better option. As you say, the other side could last for many more years and I would not change a working side for the sake of it.
Looks like the indie knew what he was talking about.Just food for thought - I may have been unlucky, but both front sensors on my S204 failed at about 50,000 miles pretty much within 500 miles of each other. NS first, then OS.
Didn't the scanner point to the correct broken sensor in the first place?Had a defective rear ABS sensor fitted to my ML by a Mercedes Indi, all ok , got 50 miles down the motorway when warning light reappeared. Turned round and drove back , when checked it was a front sensor ! They said it a not uncommon occurrence
Yes it was perfectly fine after the first one had been replaced , was checked on Star . The second one went afterwards, the car had been standing prior to the first one going , they definitely don’t like being parked up too regularly. Incidentally my second ML also had an ABS wheel sensor failure after being parked up for 3 weeksDidn't the scanner point to the correct broken sensor in the first place?
Blimey ! Looks like when one goes then it's new sensors all around !Yes it was perfectly fine after the first one had been replaced , was checked on Star . The second one went afterwards, the car had been standing prior to the first one going , they definitely don’t like being parked up too regularly. Incidentally my second ML also had an ABS wheel sensor failure after being parked up for 3 weeks
I doubt it, just unlucky, a lot of cars out there only have had a single sensor or reluctor ring fail, mine included.Blimey ! Looks like when one goes then it's new sensors all around !
didnt I say itcheck condition of reluctor ring. That most common fault
You certainly did. Along with everybody else. Thanks for your inputdidnt I say it![]()
I think the wheel question needs to be put in the correct "wheel" section in the forum. The specified load rating for my car is "W" so would think changing to "XL" would give more sturdiness to the tyre and wheel but again, think you need to post in the right section of the forum.Well done dogday, mines still behaving properly so fingers crossed..
On a separate issue, I lost a few,psi on a rear wheel which seems to be down to the fact that the wheel is no longer round, flipping potholes!
So I’ll be on the lookout for a set of alloys. Was wondering if they need to be XL or is any commercially available set of alloys claiming to fit adequate?
I can’t reply to any of the classified on here as my post count Is too little!
You’re mixing up tyres, wheels, speed rating and load rating! As you say, best asked in the wheel section.I think the wheel question needs to be put in the correct "wheel" section in the forum. The specified load rating for my car is "W" so would think changing to "XL" would give more sturdiness to the tyre and wheel but again, think you need to post in the right section of the forum.
I had a constant slow leak from a tyre on an alloy wheel on a previous car after hitting a pot hole. The wheel can get slightly distorted or you can get a hairline crack in the alloy. I told the tyre fitter about the leak and he refitted the tyre with a load more of the "paste" that they use and the tyre stopped leaking.
See what you mean. W is a speed rating, not a load ratingYou’re mixing up tyres, wheels, speed rating and load rating! As you say, best asked in the wheel section.
