Leccy Window Faulty
Thmsshaun
Ontario, Canada
2009 C300 4Matic, 2012 Kia Sportage, 2015 Triumph Tiger800 XCX
What a nightmare went to put the nearside window down and nothing. Seems like it is the motor as the diagnosis included.
Pressing the switch without engine running - Relay could be heard
Checking the fuse.
Removing door card and wiring connector from motor.
Connecting multimeter to connector and pressing switch. Multimeter gave positive & negative reading as expected for up and down.
So in conclusion all fuese ok, power getting to motor. The only thing left is the motor itself. :crazy:
Well it is covered on the warranty. Just the inconvenience of another day without the car.
Thankfully nothing serious. Just a dodgy connection. Could really kick myself though after how far I tested it myself. Still allwork not got charge £16.75 by the garage and the car was washed.
Thanks again to Burton Motor Workshop, what a great bunch of guys.
A small tip.....
never use a multimeter, especially a dmm to check for the presence of a voltage, as the impedence of these is so high that they will pick up any stray voltage.
Always use a test light, which will draw a little current. this will show that there are no bad connections.
a multimeter is great for measuring voltages though (charge voltage etc)
