Swiss Toni
- Sep 1, 2004
- Pedestrian
Another common breach of lighting regs seen on our roads concerns the use of flashing white and red lights on bicycles .
Whilst is is legal to have flashing white/red LED's showing to the front/rear these can only be used as a supplement to constantly illuminated lights and may not be used on their own .
Unfortunately , many cyclists seem to be unaware of this and ride around with ONLY flashing LED's . I suppose at least it is better than no lights at all .
I *believe* that used to be the case, but The Road Vehicles Lighting (Amendment) Regulations 2005 changed Reg 13 such that it became legal.
EDIT: (Found it!)
Regulation 6 amends regulation 13 of the 1989 Regulations so as to permit pedal cycles or trailers drawn by, or a sidecar attached to, a pedal cycle to be fitted with front and rear position lamps which flash. In the case of lamps which must be fitted pursuant to regulation 18, lamps must, when flashing, produce a light with an intensity of not less than 4 candelas.
