Left tail lamp warning on 2012 Vito w639
peterb2428
surrey
vito van and GLA220d
Hi All
So recently tail lamp left warning has appeared on the dash - all other lights working ok , have tested all connections which seem ok however only showing volts when lights on, right side is fine and shows 12 when switched on.
Any tips on what to check
So after more testing the cable required to make the light work shows 0 volts - if i link from other side all works but error meassage will obviously stay, idea is to run a single back to wiring at fuse box if i can identify the correct wire, does anyone hve a wiring schematic for this
