wilko50
- Mar 3, 2012
- W211 280 CDi -OM642- Engine
Hello to you all, I have just brought the Lidl oil extractor (below link) which seems like great value. Problem is as you probably know with the W211 the battery is in the boot, this means the cable wont reach the engine bay to run the pump.
My question is ,can I run it from the small SBC battery in the engine bay or will it drain it ? It can take 20 mins to drain the oil which is a long time draining a small battery, also on these cars will the small SBC battery take power from the main battery when low even with the engine turned off ?
I hope you can help and give advice. Thank you
Ultimate Speed Oil Pump - at Lidl UK
Ultimate Speed Oil Pump - Includes: 1 oil pump including spiral cable with terminal clamps, 1 suction hose (1.2m), 1 discharge hose (2.0m), 2 clamps
www.lidl.co.uk
