Lighting questions - Help please
NW_Merc
Banned
Over here, sometimes over there
1994 Mercedes C180 classic
I have a Merc W202, I need to know a few things
1. I have seem a W140 S class high level light and need to know if this will fit my car
2. Puddle lamps how do I wire them?
3. AMG bumper and skirts will eurocarparts do them?
4. I'm considering replacing the rear manual windows with electric, I understand that I will need to replace the door cards and so on and motors, is this easy to do?
5. I want to add a turbo set up like Koolvin's car with dump valve, a few pointers would be handy
6. Cruise control retro fit
7. Rear head rests mechanism retro fit, obviously it will need knew console and so on.. can this be done?
This is all that comes to mind at the moment
Help please
. . . no problem, do some forum searches first of all, you'll find a lot of info already exists then you'll be able to ask specific unanswered topics. Certainly headrest, puddle lamps are here somwhere.
BTW, welcome to the forum . . . ;)
Im not sure on the S Class light ,If the rake of the rear screen of the S Class differed slightly then the angle on the brake light would match that.Putting it on a W202 would then leave gaps around it which will let in condensation which will be murder to get rid of and would look tatty.I say try go for one off a W202 if you can.
Check the how to section there is a couple of threads on how to do puddle lights
