Gareth Kent
- Dec 30, 2014
Tried to put a spare on the ML last night as rear left had a big screw sticking straight through the tread. Annoyingly the locking wheel nut appears to be damaged as it can't get any purchase on the nut and is just threading. Took it to main dealer as they took the wheel off and changed the speed sensor about 8 weeks ago. They say it has to be drilled out. I would have thought spot welding another bolt to the locking nut would be best solution but they say has to be drilled out and then a new set of locking wheel nuts. Any ideas if that is best solution chaps ?
