Lots of Codes
MattEVans
Reading
2009 Vito 115
Afternoon,
I have recently got a code reader and scanned the car, I have a 2009 Vito 115.
There are a lot of codes which I have tried to clear, they all seem to be relating to sensors and ECU bits. The are
P0100 Mass Air flow
P0110 Air temp sensor
P2014 Intake Manifold Runner Position Sensor / Switch Circuit Bank
P2040 Reductant Injection Air Pressure Sensor Circuit High Input
P2041 Reductant Injector Air Press Sensor Circuit Intermittent
P2061 Reductant Injection Air Pump Control Circuit High
P2067 Fuel Level Sensor B Circuit Low
P2133 Throttle/Pedal Position Sensor/Switch F Circuit High Input
P2135 TPS Sensor Voltage Correlation DTC
P2208 NOx Sensor Heater Sense Circuit Bank 1
P2510 ECM/PCM Power Relay Sense Circuit Range/Performance
Do you think these can all have individual faults or is there a controller issue here?
I have changes the MAF and Temp sensor, but the faults are still present and unable to be reset.
What code reader do you have?
Are they current or stored codes?
I would say, if you can, clear all the codes and drive the car, see which if any come back.
