renault12ts said:With a pin?
BlackC55 said:Lowering springs for front.
Lowering rod for rear.
Alps said:you can go pretty low, as long as the wheel clears the arch and shock.
As Olly has said, an adjustable rod on rear ride height sensor.
also rememebr the lower you go the worse the camber and tyre wear on the inside
astamir said:How low you can go on 19"? And do you know a place where I can do it?
astamir said:Won't go lower than that)
How much to lower it ?
thefibreguy said:The Rentec module was £400,( purchased from a forum member). It's fully adjustable via remote control.
Sounds scary and putting me off from doing that
