M104 holds back under load
Given the list of motors you own it's a bit of a shame that you can't find someone nearer.
I had this problem with mine.it turned out to be the air mass meter
How are you getting on with this?
Mine has been diagnosed and the repair options are being evaluated.
Top troubleshooting work from both the gearbox rebuilders and the Bosch specialist, took a few days for the Bosch guy to get a look at the car but he had it diagnosed as a problem with the cold start relay in half a day.
He reckons that a couple of issues (lumpy running, intermittent stalling) I've had for months will be resolved by getting this fixed.
I gave the car a bit of work today and it pulled well as it should and consistently so it does look as though it was the weak mix causing the problems.
