BlueQuinn
The S124 passed another MoT last week, which I'm pleased about, but more oil leak advisories this year!
I seem to be chasing oil leaks round this engine.
Having fixed the cam cover, timing cover and oil level sensor leaks I now have one from somewhere near the oil filter. I guess it's leaking where the oil/water heat exchanger bolts onto the engine block. Has anyone any idea how many hours of labour I need to budget for? I guess the entire inlet system has to come off just to investigate?
I also have a leak from the gearbox overload protection switch. Quite a lot. What's the betting - switch itself or just an o-ring? I've noticed quite jerky gear upchanges recently. Does that mean the switch is bad, or just that the pressure is being relieved through the leak, so it never switches?
