Thanks for
Thanks for reply, I’ve got icarsoft and have looked at values, but I’m still learning, and by no means proficient. I’ll look again and document when cold and fully warmed up. I didn’t think they were to far off when I last looked, but if I post them next week would you be kind enough to give me second opinion. I suppose on initial start up the mixture is super rich, this is the period were motor runs absolutely rock solid, I’ve changed all fuel injectors with stock ones and still have secondary cats and I would think original O2 sensors. Is it the case that you don’t get true long term trims until the motor is hot? Sorry for all questions, but although motor has never been bad as to cut out, I do think it could be a little smother. Thanks in advance, Matt.They all have a slightly grumbly idle when cold. If yours is particularly bad, I would start with looking at the adaption values. These will give you an indication on too much fuel, or too lean at idle and what its doing to compensate. Air leaks are common and adaption values will tell you this (STFT and LTFT on OBD readers)
