The originals are glued on but I found the silicone tube to be such a good fit I never got around to gluing it.Thanks Jim, appreciate it.
For my reference, does it need adhesive to secure into a plastic ends?
I’ll give it a go at the weekend!
No problems. Good luck. It was an easy job and mine has been solid ever since. Report back how you get on.cheers Jim - ordered and will give it a go at the weekend.
thanks again
You're welcome, glad it worked out ok for youFor some reason i cannot upload photos.
However the job itself took 10ish min per side. I left it w/o the glue for couple days and that seem to have done the job. I might eventually use adhesive / cement that is used on poly pipes to seal it all… for now i’m happy the way it is .
Thanks again Jim!
