ALFAitalia
- Feb 19, 2022
- Location
- Bognor Regis
- 2010 Mercedes W212 E Class E350 CDI Sport, 2006 Mercedes W169 A Class A170.
As all you experts will know there were issues with the early cam/timing chain on the engines up to number 022333 (this seems to vary depending on source so Id like to knows the engine number if anyone knows for definite). And we know that a check valve, different tensioners as well as a new design of chain was used to cure the issue.
Old and new chain differences shown below...
But does this this mean certain failure is imminent if a owned an early chain engine or is it the case of most go on to live happy and long lives with a more frequent oil changing than stated by Mercedes. In the same way that if you read all the M156 head bolt, cam and follower stuff online you might not expect your M156 to make it to the end of the street!!!.....whereas in real life its a pretty rare failure....especially the head bolts.
So what I want to know is how many of you with early E63 212s or others with the M157 are completely original in the valve gear/drive department and how many miles you have now.....and if you did experience failure at what miles and did you have frequent fresh oil in it. And the worst case scenario......did anyone ever have one snap or slip??In other words should any potential buyer avoid them like the plague.....or is it all blown out of proportion. Obviously I'm interested in the info for my car search.....but in the future it could well be useful to others. I know there are many threads on the subject but unless I've missed it I've not seen one done as a sort of survey. Light blue touch paper....stand well back!
