E63 M157 cam position sensor
sixthree
London
2015 E63 AMG Wagon
Hi all,
I have a 2015 e63 wagon and 3 of the 4 cam position sensors are leaking. I've checked the ECU plugs/pins and there is no oil thankfully there. What is the current part that I should be looking for? Is it 2769051000?
And also what brand and where should I get them? Ideally I'd like to use MB OEM only but not sure if they ever fixed those parts to not leak again?
Thank you for your help!
I have seen a couple of videos and think they have fixed the problem? I believe there are some superceded part numbers, replace with oem only. Bit of a fiddly job, the charge pipes are in the way 👍
Thank you all!
