M271 issues
C200kamh
Stockton on tees
2005 c200 kompressor estate
Hi guys I have recently baught a c200k
And I've noticed that after 100miles or so the eml light comes on and brings
A code p2058 upstream control fault.
What can cause this issue.
Is it the sensor or a vacuum leak. How would I perform a smoke test to prove its not a leak.
And also when I start the car from cold sometimes it's sound really rough and after 1 min or so runs smooth.
Do they have a cold start valve on these engines.
Have a read :
Hi thanks for the reply.
What is a closed loop and how can I fix it.
Also my mpg is very poor low 20s at best
There’s open and closed loop on modern fuel injected cars, open loop is achieved on cold start , and runs on a set map stored within the ecu, such things as cold start enrichment, closed loop is when the engine relies on inputs, such as oxygen sensor, maf and coolant temp, closed loop is achieved by the oxygen sensor getting to a certain temperature so it can function, then the ecu can fine tune fueling to be at its best, your car is not running right in open loop
So how do I go about fixing the issue.
What are the causes for this to happen.
Any help would be much appreciated
It sounds like a faulty o2 sensor. Usually they fail on this engine due to oil ingress in the engine wiring loom that comes from a cam magnet. Take the o2 sensor connectors off (there are two of them) and see if there is any oil in there.
